grid size
what should be the criteria for making the grid?
Re: grid size
Numerical diffusion shuld not take place hence aspect ratio should be 5:1. Wall y+ need to be 30 for turbulent flows. Square cells should be used. Near the inlet of bubble column (Yao et al.case for instance) meshes should be fine comapred to other parts of the column. kp@dal.ca
Re: grid size
what do u mean that aspect ratio should be 5:1?
