Courant Number - Multigrid level - Residual Smooth
Hi !
I'm trying to simulate a shock wave on a 30mm shell, Mach 2.4. I'm not using Fluent or a long time and I would like to get some explanations about the "Solution Controls" setting. What does mean Courant Number, Multigrid level, Residual Smoothing, and how to set them ? (does the "smoothing" option helps in adapting the grid for a better accuracy ??) I'm working under an operating pressure=0Pa, pressure far field 101325Pa/Mach2.4 (for inlet and outlet). Solver coupled/explicit/axi, ideal gaz and laminar. I tried First Order Upwind discretation scheme, which gives a better convergence. I kept the default courant number(=1). Many thanks by advance. |
