How can I monitor pressure at a point?
Hello, I'm doing unsteady calculation and I want to monitor the pressure at a fixed point for each timestep. How can I do that in fluent? Thanks.
Re: How can I monitor pressure at a point?
1 difine point:surface--point(input cordinates of point wanted) 2 solve--monitors--surface--fill your information to dialog table(to choice "pressure" under report...
Thanks a lot man!
Hello, I followed your steps but the static pressure is always 0. What should I choose for 'Report Type'? I chose 'Integral'. Thanks again.
Choose area weighted average. Also save the values at every time step, not every iteration.
Thank you!
I want to monitor a pressure at a point which attached in moving wall. How can I make this point moving together with the wall?
I know this is an old topic, but I actually want to do the exact same thing as freeday but haven't been able to find a solution for it. Isn't there is simple way to move your monitor? |
Hello All,
I have extracted the pressure as mentioned above but unfortunately pressure value is not matching with the experimental value with similar wave characteristics. More specifically, I am interesting in dynamic pressure.
Can anybody help me to find out the exact reason:) Thank you in Advance! |
