multiphase system, segmentation violation error |
March 30, 2006, 08:59 |
dear all,
i am using eulerian model to simulate a circulating fluidized bed containing sand and air. currently i am using a very simple geometry. it is a rectangular duct, with air blowing from the bottom face, and air-sand mixture exiting from the upper face. there is a total reflux of the sand particles exiting from the top. the reflux occurs from one of the side faces in the bottom section. i have written an interpreted UDF for evaluating the recirculation, and it had no errors during the interpretation. the problem occurs during the initialization. when i try to initialize the parameters in the 3d volume -i enter arbitrary values myself- i get the "SEGMENTATION VIOLATION" error. i suspect there might be some BCs that are not properly defined. could that be the case? or any other suggestions? it also says "Error object: #f" among many lines in the error log. thanks for any help in advance. kerem |
April 3, 2006, 05:42 |
Re: multiphase system, segmentation violation erro
it came out that it resulted from a BC type that I used which is not available for the EMMM
polynomial thermophysical properties II | sebastian | OpenFOAM Running, Solving & CFD | 54 | November 21, 2019 07:12 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
