Home > Forums > FLUENT
Pressure drop
Old   April 6, 2006, 15:02
Default Pressure drop
Paul_C
Hello
how can i find the pressure drop across a 2D tube?
Can i use the value given in the pressure contour plot to subtract or do i need to use surface integral to get the pressure?
Please advice
Old   April 6, 2006, 17:27
Default Re: Pressure drop
Ravi Kumar Duggirala
what are your BCs. If you are using Periodic BCs... then its pretty easy Let me know bye Ravi
Old   April 7, 2006, 00:51
Paul_C
I have velocity inlet and outflow
Thanks
Old   November 17, 2012, 08:50
Kamu is on a distinguished road
Originally Posted by Ravi Kumar Duggirala
;131029
Hello Ravi, I have periodic BCs and I can not figure out how to get the pressure drop. I tried dp/dz where z-is my streamwise direction the pressure drop I get is different from the pressure gradient in the periodic boundary conditions! After getting this pressure drop how do i use it to get my friction factor since it will be per meter
Kamu is offline   Reply With Quote
Thread Tools
Trackbacks are On
pressure drop in the pipe mike.mm FLUENT 6 February 7, 2011 10:31
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
Total and static pressure drop Janakiram CD-adapco 1 February 8, 2009 01:32
Pressure Drop at entrance of a rotor-stator. Resnick Main CFD Forum 0 November 20, 2007 14:50
Periodic boundaries and pressure drop MatejK CFX 2 July 12, 2005 04:47
