March 21, 2006, 03:34 |
VOF for flow problems with inlet and outlet
hello,
Anyone have any experience in using VOF model for flow in a channel before? Would appreciate it if any one can offer any advice Thanks |
March 21, 2006, 09:56 |
Re: VOF for flow problems with inlet and outlet
What is it that you are struggling with?
March 22, 2006, 02:03 |
hello
i am just simulating the flow of a slug bubble flowing in a mini channel. however i cannot get the expected bubble shape. may i know whats the problems? thanks for your help |
March 28, 2006, 10:19 |
Well, don't use outflow for one thing, it's not supported (even though you can select it).
Beyond that, use a fine mesh to render the interface well and a small enough time step (I usually have to use one less than the one suggested by the Cr=0.25 value). Make sure to include surface tension... |
April 4, 2006, 03:38 |
Dustin
Thanks for your help do you include wall adhesion? also can u furnish me with more details for the model that i should use? Do i use geo-reconstruct or implicit scheme. how about the ralaxation factor? hope u can help me with this |
April 4, 2006, 06:40 |
- Usually, I try to run a simpler case without wall adhesion first, to make sure everything else is kosher, then I add the contact angle info in.
- Most of the time, Euler-Explicit with PISO, PRESTO and 2nd Order Momentum for VF and momentum work well for me. - And I if I didn't mention before, try using as small a time step as is feasible. - Relaxation factors should be fine as the default values, but you mayu need to lower momentum to 0.5 or so. Good luck - Dustin |
April 4, 2006, 10:02 |
Heh thanks alot i will give it a try
April 6, 2006, 14:15 |
sorry to bother again
but can i check with you if VOF assumes that there no slip between the liquid and the gas phase. Thank again |
April 6, 2006, 14:26 |
#9 |
VOF averages the properties of the fluids over an interfacial region.
I would guess that's not the answer you want - Dustin |
April 6, 2006, 14:37 |
#10 |
ya and a momentum equation is used for the entire domain.
But how can we intreprete the fact that the properties is being averaged? does that means that at the interfacial region the velocity of the gas and liquid phase are the same giving slip flow at the boundary? Thanks in advance for your help |
April 6, 2006, 14:46 |
#11 |
I'm shooting from the hip on this one, so it ain't gospel.
I think so (that the same wall slip velocity would be used at the interface). Contact angle/wall adhesion would dominate this process (I think) for most cases. But, wrong may I be.... |
April 6, 2006, 14:56 |
#12 |
haha okok thanks for your kind help.
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
plz rply urgent regrding vof model for my system | garima chaudhary | FLUENT | 1 | July 20, 2007 08:37 |
urgent query regarding vof model plz rply | Garima Chaudhary | FLUENT | 0 | July 13, 2007 02:20 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 08:07 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
