How to control pressure jump in a fan?
Old   April 7, 2006, 06:35
Default How to control pressure jump in a fan?
Ana
I'm doing a project in which I need to create the performance curve of a fan (pressure jump versus flow rate) and I'm having problems with the boundary conditions, I have tried pressure inlet and pressure outlet, 2 pressure outlets and finally mass flow inlet and outflow. With the last one Fluent doesn't make anything, and tells me that k diverges.
Can somebody tell me which one of the 3 boundary conditions is better for my purpose, and if it is the third one, does anyone know what the problem is?
Thank you
Old   April 8, 2006, 08:25
Default Re: How to control pressure jump in a fan?
Ahmed
Tutorial 8, Using multiple rotating reference frames deals with a centrifugal blower, pressure-inlet and pressure outlet are used, k-epsilon turbulence model. Check your mesh and Good Luck
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
pressure jump in fan boundary condition Vijay FLUENT 0 February 12, 2009 18:19
SST in 2D? Jesper Sørensen CFX 16 December 23, 2006 08:40
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
