Free surface, open channel
I am using the tutorial on http://www.studentfluent.com to look at the flow over a cylinder. Now I want to have an free surface at the top and my second fluid at the top is just atmo. what I have done so far is:
Turned on Gravity and set the gravitational acceleration in x direction to 9.81 m/s^2 Enabled the volume of fluid model. Opened the Multiphase Model panel >>> Models Multiphase... turned on Volume of Fluid. Under VOF Scheme, I need to select either Implicit, Explicit, or Geo-Reconstruct, which on should I use? Under VOF Parameters,I have selected Open Channel Flow. Would that be all the neccessary parameters ? thanks for the help :) |
Re: Free surface, open channel
I guess you want to catch the interface between both your fluids...You have to choose the Geo-Reconstruct scheme. Try to keep the defaults parameters
Hi, If you want to run transient simulation, the best is Géo-Rconstruct to catch the interface.(Euler and Géo-reconstruct are necessary in transient mode i remenber) if simulations need too long time, you can try VOF-Implicit in steady-time run.
Other parameter are: -indicate each fluid for the two phases in the panel 'Multiphase' -turn on operating density in 'operating condition' (indicate the lowest denisty of the two fluid) -Indicate inlet and outlet boundary condition for each phase -You have to use Body Weighted solver (if gravity is activated) and PISO (with 0 Skewness correction) I hope this can help me correct me if error |
