Free surface, open channel
Old   April 8, 2006, 05:21
Default Free surface, open channel
Linda
I am using the tutorial on http://www.studentfluent.com to look at the flow over a cylinder. Now I want to have an free surface at the top and my second fluid at the top is just atmo. what I have done so far is:
Turned on Gravity and set the gravitational acceleration in x direction to 9.81 m/s^2
Enabled the volume of fluid model.
Opened the Multiphase Model panel >>> Models Multiphase...
turned on Volume of Fluid.
Under VOF Scheme, I need to select either Implicit, Explicit, or Geo-Reconstruct, which on should I use?
Under VOF Parameters,I have selected Open Channel Flow.
Would that be all the neccessary parameters ? thanks for the help
Old   April 8, 2006, 16:18
Default Re: Free surface, open channel
Carnot
I guess you want to catch the interface between both your fluids...You have to choose the Geo-Reconstruct scheme. Try to keep the defaults parameters
Old   April 10, 2006, 11:43
soy
Hi, If you want to run transient simulation, the best is Géo-Rconstruct to catch the interface.(Euler and Géo-reconstruct are necessary in transient mode i remenber) if simulations need too long time, you can try VOF-Implicit in steady-time run.
Other parameter are: -indicate each fluid for the two phases in the panel 'Multiphase' -turn on operating density in 'operating condition' (indicate the lowest denisty of the two fluid) -Indicate inlet and outlet boundary condition for each phase -You have to use Body Weighted solver (if gravity is activated) and PISO (with 0 Skewness correction)
I hope this can help me correct me if error
Open Channel Flow ElanMorin FLUENT 4 February 25, 2015 16:26
CFX convergence issues with free surface adenlan CFX 3 September 2, 2011 06:43
Open Channel Boundary Conditions via journal Matteo FLUENT 0 January 21, 2008 11:05
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
pressure outlet (open channel flow) Willem Brantegem FLUENT 2 April 4, 2007 02:40
