Home > Forums > FLUENT
flow over cylinder
Old   April 8, 2006, 12:35
Default flow over cylinder
shan
Hi in flow over cylinder problem, how can i plot the pressure coefficient vs various angle of cylinder. presently it is plotting pressure coeff vs radius of cylinder. how can i make the X axis in terms of angle. Thanks in advance.
Old   April 8, 2006, 14:59
Default Re: flow over cylinder
Freeman
Switch on the "on curve length" option in the same window you select the "Pressure coefficient" plot. When you swhiched on this option you, you must select the curve of your cilinder (the edge). That's all
Hope this helps a bit. Bye!
Old   April 12, 2006, 05:50
sujay
u will not be able to plot u have to go for some other software
Thread Tools
Trackbacks are On
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
1 Was FSI for a flow over a cylinder vmlxb6 CFX 17 May 16, 2011 02:29
Moving a Cylinder in cross flow after solving Dynamics equations of motion maruthamuthu_venkatraman OpenFOAM 1 November 19, 2009 14:55
Flow over a flat plate & Flow over a cylinder cfdxue Main CFD Forum 0 November 27, 2007 00:26
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 15:32
