heat conduction with temperature profile BC's
Old   April 11, 2006, 11:34
Default heat conduction with temperature profile BC's
Arnout
Hi, I have a problem with simulating heat conduction through a solid, based on experimental measurements. As boundary condition at the bottom I insert a heat flux. The temperature profiles at the other sides were measured and put in the FLUENT model as temperature BC. Now we want to know the heat flux at each point, but this gives strange values. We get positive and negative fluxes at the walss with temperature BC's, and we expect only negative fluxes. What can be the problem? We did not define any fluid side, but I think that this is not the problem.
Greetings,
Arnout
Old   April 14, 2006, 08:30
Default Re: heat conduction with temperature profile BC's
Chandra Murthy
Your problem is looking like inverse heat conduction problem. Fluent cannot solve inverse heat conduction problem, by default. You need to write a UDF, and solve it 1D approach.
Heat transfer (conduction) between two pipes shields FLUENT 14 February 3, 2016 07:45
heat conduction in solid and convection in flow kunal FLUENT 3 February 29, 2012 04:42
Need Help on Heat Flux Profile within Pipe Wall mep10jl FLUENT 3 June 6, 2011 17:08
Heat Exchanger Fluids Lack Temperature Difference justinF FLUENT 2 July 11, 2007 22:55
