April 8, 2006, 12:35 |
flow over cylinder
Hi in flow over cylinder problem, how can i plot the pressure coefficient vs various angle of cylinder. presently it is plotting pressure coeff vs radius of cylinder. how can i make the X axis in terms of angle. Thanks in advance.
April 8, 2006, 14:59 |
Re: flow over cylinder
Switch on the "on curve length" option in the same window you select the "Pressure coefficient" plot. When you swhiched on this option you, you must select the curve of your cilinder (the edge). That's all
Hope this helps a bit. Bye! |
April 12, 2006, 05:50 |
u will not be able to plot u have to go for some other software
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
1 Was FSI for a flow over a cylinder | vmlxb6 | CFX | 17 | May 16, 2011 02:29 |
Moving a Cylinder in cross flow after solving Dynamics equations of motion | maruthamuthu_venkatraman | OpenFOAM | 1 | November 19, 2009 13:55 |
Flow over a flat plate & Flow over a cylinder | cfdxue | Main CFD Forum | 0 | November 26, 2007 23:26 |
Flow over a cylinder | Anna | Main CFD Forum | 9 | March 24, 2006 14:32 |
