April 14, 2006, 11:48 |
udf problem
I am running a simulation in which the heat flux from the wall to the fluid flowing inteh channel varies linearly with the x co ordiante (independant of the other co ordiantes) i wrote the udf for it but it gives this error every time i run it.
chip-exec: heat_flux: argument 1: incorrect type (31): int expectedchip-exec: heat_flux: argument 2: incorrect type (5): pointer expectedchip-exec: heat_flux: argument 3: incorrect type (-842150451): int expected Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () my udf program is as folows #include<udf.h> #DEFINE C1 39682.5 #DEFINE C2 2645502.646 DEFINE_PROFILE( heat_flux,thread,i) { real pos_vec[ND_ND]; real x; face_t f; begin_f_loop(f,thread) { F_CENTROID(pos_vec,f,thread); x=pos_vec[1]; F_PROFILE(f,thread,i)=C1 - C2*x; } end_f_loop(f,thread) } please help me thanks in advance |
Display Modes | |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 07:05 |
Problem with my udf | july | Fluent UDF and Scheme Programming | 3 | June 20, 2010 07:56 |
UDF problem | mansha goraya | FLUENT | 0 | October 29, 2007 01:31 |
udf compiling problem | akr | FLUENT | 3 | August 22, 2007 08:14 |
UDF problem | chiseung | FLUENT | 4 | January 10, 2002 10:58 |
