HELP! how to use C_R_G(c,t,) correctly?
Old   April 15, 2006, 11:09
Default HELP! how to use C_R_G(c,t,) correctly?
wicwawa
Hi, here is my UDF codes for a source. I am using Fluent to simulate PEM fuel cell.
I use the density gradient(y direction) to calculate the Net water transfer coefficient. But when i initialize it, error occur: access violation.
DEFINE_SOURCE(H2O_A,c,t,dS,eqn
real source7,nd;
nd=2.5*16.8/22;
source7=nd*5.5E-11*(C_YI_G(c,t,2)[1]*C_R(c,t)/M_h2o+C_R_G(c,t)[1]*C_YI(c,t,2)/M_h2o);
dS[eqn]=0;
return source7;
I also experiment simple source item using C_R_G(c,t)[1],but the same error appear.
When delete the C_R_G(c,t)[1], it will be ok.
Can everybody know what's wrong with my code. How to use C_R_G(c,t)?
THX in advance
How to use dynSmagorinsky model correctly ? panda60 OpenFOAM 121 July 14, 2016 13:09
[ICEM] Procedure : how to mesh correctly two semicircles in an air flow ? eeesprit ANSYS Meshing & Geometry 2 April 10, 2011 15:14
How to correctly set the mass flow rate of solid paricles ? sankarv OpenFOAM Running, Solving & CFD 0 April 18, 2010 18:04
Can C_VOLUME return value correctly? blueberry FLUENT 6 May 8, 2007 01:30
how correctly set up BC for compressible flows.... yann Phoenics 5 October 13, 2003 03:35
