Why it is not converge in DPM calculation?
Like Tree2Likes
  • 2 Post By Markus
Old   April 17, 2006, 14:20
Default Why it is not converge in DPM calculation?
Josh
I calculate DPM with 1000 particles from a nozzle, The continuity vibtrates betwen 10-2 and 10-3. Why it is not converge/ Thanks for any suggestions.
Josh
Old   April 18, 2006, 05:48
Default Re: Why it is not converge in DPM calculation?
RAO
you can try it with lower under-relaxation factors of Discrete Phase Sources
Old   April 18, 2006, 22:58
Markus
I've had some difficulty getting DPM models to converge with some recent simulations. Here are a few tips to improve stability:
- solve for strictly turbulent flow first (disable Energy, PDF and radiation model [if applicable]). Once turbulent solution is converged, enable these equations. - solve for uncoupled DPM first - once uncoupled flow reaches convergence (or close to), enable interaction with continuous phase. Use an URF of about 0.1. - increase # of continuous phase iterations per DPM iterations (try 100) - increase # of tries, if DRW model is enabled
xq712000 and GeoFluid like this.
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
Droplet Collision Efficiency Calculation using DPM Virk FLUENT 0 January 22, 2010 09:37
VOF with tetra mesh doesn't converge Gregor FLUENT 1 March 1, 2005 13:09
Warning 097- AB Siemens 6 November 15, 2004 04:41
If it's right to use this UDF in DPM calculation? welch FLUENT 0 May 8, 2004 05:49
