Gambit journal - Split edge & rename new vertex |
April 18, 2006, 06:25 |
Hi !
I'm trying to edit a journal to add a geometry and mesh to an existing geometry (numbrer of vertices, edges & surfaces is unknown). In order to avoid confusions, I renamed all new vertices "vertex.1000", .2000, etc. One point was created by splitting an edge : "edge split "edge.3000" percentarclength 0.15 connected" That works, but I would like to rename the new vertex in the same time. As I don't know his name, is it possible whithout using "vertex modify label" ?? |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 01:30 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
