-   -   BC's details unavailable from imported msh file (http://www.cfd-online.com/Forums/fluent/40653-bcs-details-unavailable-imported-msh-file.html)
ashish April 19, 2006 14:40
Dear chandra and zxaar
as per the advise received from you, In Gambit I had imported *.msh file from fluent *.cas file. But the boundary conditions details are not available in the *.dbs file? how will I get the boundary condition details in the dbs file so that I can edit the bc's and export new msh file for fluent run.
zxaar April 19, 2006 18:09
Re: BC's details unavailable from imported msh fil
when you extract mesh from .cas file as i mentioned the boundary conditions are available.
ashish April 20, 2006 01:06
I get the following error: is this a very serious error, please help.
Starting /pkgs/gambit2.0/Fluent.Inc/utility/fe2ram4.3/ultra/fe2ram.4.3.2 -m1e-06 -d3 -tRAMPANT -oFIDAP7 /home/ashish/3dmodel.cas.tar.cas
RAMPANT file to FIDAP7 file
Read 1994678 nodes, 1868000 elements, 14 groups. 1868000 hex elements
merged 0 nodes (1994678 remain)ERROR() error code = 101077
WHERE = -?- ERROR() error code = 101077
WHERE = -?-
Thanks a lot.
zxaar April 20, 2006 04:30
why is the model compressed, uncompress it and see if it changes anything. Anyway it should have already worked i guess.
ashish April 20, 2006 08:06
I will try and get back.
ashish April 23, 2006 04:29
Hello zxaar,
the boundary conditions are available in the mesh file, but when i import the mesh in gambit i do not see the boundary conditions details, can you please help.
thanks.
ashish April 23, 2006 06:47
Hello zxaar
one more thing which i found was when i read the msh file thus obtained as above and read in fluent i find that the zone id's have changed and when i solve i get the Floating Point Exception (Underflow) Error. this was not the case with the original fluent case file. can you please help.
thanks,
ashish.
zxaar April 24, 2006 06:56
if you use the latest version of gambit, you will see it preserves the boundary condition names as they were.
zxaar April 24, 2006 07:24
use journal file to describe the boundary conditions etc, when you describe BCs by TUI you can just use their name to specify the BC, you do not need the zoneid, let it change.
ashish April 24, 2006 08:13
i specified the bc's in gambit and exportet the mesh, but while solving in fluent i get the error. where as the original case file does not give any error.
please help.
regards,
ashish.
zxaar April 24, 2006 08:45
you haven't told what error it gives.
ashish April 24, 2006 11:26
Hello zxaar
I though that you have read my earlier message in this thread:
"one more thing which i found was when i read the msh file thus obtained as above and read in fluent i find that the zone id's have changed and when i solve i get the Floating Point Exception (Underflow) Error. this was not the case with the original fluent case file. can you please help."
thanks,
ashish.
zxaar April 24, 2006 18:14
i also thought you have read my other message, See when you read the mesh, and if you do not want to describe them again and again manually. describe them with the help of journal file. If you do this way, you do not need to worry about zoneid, you can specify by their names. So create a journal file to do the work for you. I will put and example here, or on wikipedia in FAQ section today.
zxaar April 24, 2006 21:26
Here is an example of journal:
define boundary-conditions velocity-inlet inlet n n y y n 10 y n y 0 0.001 define boundary-conditions pressure-outlet outlet n 101325 n n y n y 2 0.001 n define boundary-conditions fluid rotzone n n n n n y 0 0 0 -50.00 0 0 0 0 0 1 n n n
put these things into a journal and read the journal, you can note that i have not used the zoneid but the zone name, inlet and outlet,
ashish April 25, 2006 00:08
thanks for your journal. i will use this and get back.
regards,
ashish.
zxaar April 25, 2006 01:14
you might have to create your own suitable to ur case, its easy to do it.
