-   -   Exporting BC's from one case file to another (http://www.cfd-online.com/Forums/fluent/40673-exporting-bcs-one-case-file-another.html)
Mazyar April 20, 2006 20:21
Thanks for your interest in reading my question.
Do you have any idea how we can copy/export the boundary conditions of a case file to another case file? I am asking this because when I make a modification in the geometry or the mesh and I import it in FLUENT, I need to define again all the boundary conditions which can be pain.
Thanks, Mazyar
gernot April 21, 2006 02:04
Re: Exporting BC's from one case file to another
Itīs possible about the text-user interface.
The comand to export :
file write-bc nameofbc
The comand to import
file read-bc nameofbc
Anne April 21, 2006 12:40
In text UI, type File. Then type write-bc Then input temporary filename, ex: bc-example All material properties and BC will be saved on file you typed above.
Open new cas file. type file then, type read-bc then type temporary filename that you used. ex: bc-example. Then, all BC and material properties you saved will be loaded on your new cas file.
Thanks
ashish April 22, 2006 05:03
it is a good advise i have benefitted. i also have a question related to this, when i do some modification in a geometry and read the case in fluent, i find the zones and id change. how do i keep the zones and id's same in new case and apply the old bc's.
Thanks for your reply.
