-   -   variable inlet velocity (http://www.cfd-online.com/Forums/fluent/40735-variable-inlet-velocity.html)
Sascha Behrens April 25, 2006 04:29
id like to have a variable inlet velocity in order to simulate a pulsed stream.
As far as I know it can be done by using UDFs.
Can anybody help me out here and maybe give me some idea on how to do this? Ive never worked with UDFs before.
Thanks
Sascha
salvatore Cito April 25, 2006 05:31
Re: variable inlet velocity
Hi you can find the solution to your problem in the FLUENT 6.2 UDF Manual at the chapter related with the DEFINE_PROFILE macro that is the 4.3.13, there is an example in which a variable mass flow rate is introduced as a boundary condition, you can modify easily this udf to a variable velocity profile. good luck
