variable inlet velocity
Old   April 25, 2006, 04:29
Default variable inlet velocity
Sascha Behrens
iŽd like to have a variable inlet velocity in order to simulate a pulsed stream.
As far as I know it can be done by using UDFs.
Can anybody help me out here and maybe give me some idea on how to do this? IŽve never worked with UDFs before.
Thanks
Sascha
Old   April 25, 2006, 05:31
Default Re: variable inlet velocity
salvatore Cito
Hi you can find the solution to your problem in the FLUENT 6.2 UDF Manual at the chapter related with the DEFINE_PROFILE macro that is the 4.3.13, there is an example in which a variable mass flow rate is introduced as a boundary condition, you can modify easily this udf to a variable velocity profile. good luck
Unexpected difference between velocity / mass-flow inlet jpo FLUENT 8 December 10, 2010 07:20
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 13:02
Pressure Inlet Velocity prapanj OpenFOAM 11 June 23, 2009 11:15
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 09:44
