-   -   mixing plan problem (http://www.cfd-online.com/Forums/fluent/40782-mixing-plan-problem.html)
ravindra bankar April 29, 2006 05:02
mixing plan problem
sir/madam,
i am student of Mtech turbomachines from s.v.N.I.T. surat, Gurat state, India. I am doing my Mtech project work and i have to do analysis of axial flow compressor in Fluent 6.2. Problem : I have created inlet flow and exit flow domain and blade domain with blade at Center both for rotor and stator. As my rotor is highly twisted, for stage analysis i have taken two blade domain and one stator domain. I have generated mesh and transport to fluent 6.2 all boundary condition i have given properly. mixing plan generated . here only i am facing problem mixing plan is generated but it is not exchanging temperature from rotor to stator and back . i am getting all relative vectors in direction of flow . i am getting mass flow out of stator . upto rotor outlet rise in total temperature is there. At stator inlet it is taking temperature as 303K what i have give at inlet of rotor. rotor outlet also i am getting same temperature . due to this i am unable to get efficiency in turbo report. also as back pressure (static) rising mass flow reduces but Pressure does not increases. so please help me in this regard so that i can solve this proble with in small time to complet my project work . thanking you
ravindra bankar
sam May 11, 2006 06:43
Re: mixing plan problem
why r u using two sectors of rotor ???????????????? . u can use one of each. that is wat called mixing plane.
plz be touch for more discussion
ravindra May 12, 2006 03:41
sir, sam thanks for support. i have slove my problem by using two stator and single rotor. thanking you. by ravindra
