error messege in fluent
Old   April 24, 2006, 00:43
Default error messege in fluent
lk zhu
Hey everyone,
Thanks for your interest in reading my question.
some error messege puzzle me all the time,just like follows (1)Error: divergence detected in AMG solver: y-momentum Error Object: ()
(2)Error: Too many (2720692067) VOF sub-timesteps. The velocity field is probably diverging. Please check the solution,and reduce the time-step if necessary. Error Object: ()
I don't now why them appear.who can tell me how i can do to solve this problem.
Thanks in advance for any replies
zhu
Old   April 25, 2006, 03:51
Default Re: error messege in fluent
lk zhu
HELP!!!!
Old   April 25, 2006, 12:15
RAMESH K
Hi, I got this error few times but then i think it is due to rapid increase in the values for which the divergence has occured. u may have to reconsider the control values and other values of your solution. this is my guess. Ramesh K
Old   April 26, 2006, 23:01
lk zhu
thank you very much.i will have a try
Old   April 27, 2006, 08:37
lk zhu
Thank you Ramesh K for your response!
But I have another question about my problem: I have reduced my time step size to very very small.If i want improve my efficiency,how can i do for it?
Old   April 30, 2006, 13:01
RAMESH K
Hello, I think time step should be assigned by calculation making your courant number(minimum cell length/velocity). If you adopt this one you will get an idea of how the time step has to be taken. if your intention is to capture the fluid phenomenon at that particular level then go for small time steps or else it is good that you can have higher time steps.
Ramesh.K
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
