-   -   Vortex Generators (http://www.cfd-online.com/Forums/fluent/40788-vortex-generators.html)
Ben Cho April 30, 2006 12:51
Vortex Generators
Hi all,
I've been trying to model the effect of vortex generators in delaying stall on a NACA0012 wing using fluent. I know that they delay stall since I've experimentally confirmed this, but when I run my cases in FLUENT, I get no effect. This is my case:
Wall bounded flow. k-epsilon tuburbulence model, realizable, enhanced wall treatment, pressure gradient effects. Re = 100 000. turb intensity = 1.5%. turb length = 0.0077m.
Basically, I'm modeling a point where on the old wing, we would be in the post stall region, but in the wing with the voretex generators, I would still be pre-stall.
Note for enhanced wall treatment, my y+ is less than 0.35 for the wing and less than 1.4 for the boundaries.
Any ideas? I'm getting really frustrated :).
Thanks in Advance. Ben
Riaan May 5, 2006 00:59
Re: Vortex Generators
Well, for starters, predicting CLmax is not an easy task. Doing CFD of the vortex generators (sub boundary layer I assume) is going to be tough, because you need a lot of cell density to capture the vortex core.
I would probably saying that if you do a particle trace from the vortex generators and see no vortex - then your grid is too course.
