Home > Forums > FLUENT
overflow boundary condition
Old   May 1, 2006, 22:12
Default overflow boundary condition
Marangoni
Hi:
I am using fluent to simulate the flow inside a rectangle tank (top is opening). Liquid is fed from bottom, and exits from top. Since top is open, liquid overflow from the top. I tried both pressure outlet and outflow boundary for the top surface. The result is not realistic (flow exits from center of top surface, instead of side of top surface). Any advice on what boundary condition I should use?
many thanks
marangoni
Old   May 2, 2006, 00:25
Default Re: overflow boundary condition
Peter
Try extending your domain, like a sudden expansion on the top?
Old   May 2, 2006, 02:53
mehmet
it is a free surface at top, and make sure gravity is in effect...
Old   May 2, 2006, 09:38
philipov
Look at the domain size and velocity. I mean, if velocity is one mangnitude with domain height you can expect such results. Follow the first comment.
Thread Tools
Trackbacks are On
Can anyone give me some hint on how to make traction free boundary condition? poplar OpenFOAM 3 January 14, 2015 03:37
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
Domain Imbalance HMR CFX 3 March 6, 2011 21:10
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
