May 3, 2006, 05:18 |
data export
Could anyone help me with exporting velocity data? I've simulated pipe with periodic zone and i am interested in areas of velocities through periodic zone (doesn't matter, could be any inlet, outlet zone). Exactly as it is on a contour plot of velocity magnitude. But I want to know areas of those contours in the range of interest (ie. 0.1-0.3).
May 3, 2006, 10:50 |
Re: data export
Just go to plot-xy then set your directional vector then tick on write data, then write *.dat file. You can read the *.dat in any postprocessing software i.e. Techplot or even excel.
May 3, 2006, 16:45 |
Re: data export
Thanks for quick respond. The problem is that my mesh consists of cels of different sizes and I am interested in area of specific welocites ranges. I am using so far the file/export method with both velocity magnitude and Z face area and then counting areas in Excel. The problem is that it is not possible to obtain such a good itnrepolation of areas shapes for whole outlet face. That's why I want it to be done by fluent. Histogram of velocities doesn't help either, becouse it counts numbers of cels not the area (and don't use interpolation).
May 3, 2006, 18:29 |
Re: data export
Some post-processing software might help you to do that like Techplot or surfer for example. If you grid is 'good' and your 'directional vector' is correct it shouldnt be any problem in the plot.
May 4, 2006, 05:20 |
Re: data export
Thanks a lot. I search the web and I've found tecplot (is this what you mean?). Fluent can save data in its file format and tecplot can cut slices through surfaces and export them to data files as curves. Then the integration can be done even in Excel. So the problem is solved.
May 4, 2006, 05:24 |
Re: data export
exactly tecplot 10.0.6 with cfd analyser 4. this is a cool software for CFD. good luck.
Display Modes | |
Export data in text file | Eferal | FLUENT | 5 | April 13, 2018 11:33 |
how to export every data w.r.t time to txt file | jaho | CFX | 94 | August 25, 2015 10:45 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 02:24 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
