Vortex Generators
Old   April 30, 2006, 12:51
Default Vortex Generators
Ben Cho
Hi all,
I've been trying to model the effect of vortex generators in delaying stall on a NACA0012 wing using fluent. I know that they delay stall since I've experimentally confirmed this, but when I run my cases in FLUENT, I get no effect. This is my case:
Wall bounded flow. k-epsilon tuburbulence model, realizable, enhanced wall treatment, pressure gradient effects. Re = 100 000. turb intensity = 1.5%. turb length = 0.0077m.
Basically, I'm modeling a point where on the old wing, we would be in the post stall region, but in the wing with the voretex generators, I would still be pre-stall.
Note for enhanced wall treatment, my y+ is less than 0.35 for the wing and less than 1.4 for the boundaries.
Any ideas? I'm getting really frustrated .
Thanks in Advance. Ben
Old   May 5, 2006, 00:59
Default Re: Vortex Generators
Riaan
Well, for starters, predicting CLmax is not an easy task. Doing CFD of the vortex generators (sub boundary layer I assume) is going to be tough, because you need a lot of cell density to capture the vortex core.
I would probably saying that if you do a particle trace from the vortex generators and see no vortex - then your grid is too course.
Vortex generators : In car design jits_aps90 Main CFD Forum 1 July 30, 2009 04:25
Air-Jet Vortex Generator, request for some papers ROOZBEH Main CFD Forum 0 July 12, 2008 10:27
Modeling the Effect of Vortex Generators on Wings Ben Cho FLUENT 0 April 19, 2006 12:19
turbulent scales of forced vortex and free vortex lcw Main CFD Forum 3 September 1, 2005 13:40
Vortex generators Dave brown Main CFD Forum 1 June 7, 2000 17:24
