high speed flow with air dissociation
Old   May 4, 2006, 06:43
Default high speed flow with air dissociation
Victoria
Does anyone could give me some info about the Fluent capability to simulate hypersonic flows (mach > 5) with chemical reactions?
In particular is there any conflict using compressible ideal gas with finite-rate model (Arrhenius law-Kinetic theory) for the dissociation phenomena?
Is it correct to implement Pressure far-field boundary with compressible ideal gas and finite rate model?
Any suggestion will be really appreciated!
Victoria
Old   May 5, 2006, 11:53
Default Re: high speed flow with air dissociation
Chandra Murthy
there is no doubt...fluent can solve it (Fluent does not have mach number limitation)...but at higher mach numbers ideal gas law does not hold good... and you have to incorporate air chemistry as you have mentioned..in fluent bechmarks you can find the hypersonic problem...
High Speed multi phase flow jonita Macyte Main CFD Forum 0 March 19, 2010 06:46
high speed flow Mac Siemens 2 July 1, 2008 07:39
About the flow around moving objects with high speed luckyluke OpenFOAM Running, Solving & CFD 2 February 21, 2006 23:23
high speed gas flow the surface of powder bed? lily CFX 3 November 12, 2005 02:17
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
