-   -   UDF for unsteady spray (http://www.cfd-online.com/Forums/fluent/40843-udf-unsteady-spray.html)
Fernando May 5, 2006 14:13
Hi to all
Can anybody enlighten me in the writing of an UDF to define unsteady mass flow rate in a spray? I have tried the subroutine below but it does not want to compile.
#include "udf.h" #include "surf.h" #include "dpm.h"
DEFINE_DPM_INJECTION_INIT(pulse_spray, I) {
real spray;
Particle *p;
cell_t cell;
Thread *cthread;
loop(p, I->p_init)
cell = P_CELL(p);
cthread = P_CELL_THREAD(p);
real t=RP_Get_Real("flow-time");
P_FLOW_RATE(p) = 0.00011+0.00009*cos(200*M_PI*t);
spray=P_FLOW_RATE(p);
return spray
Thanks
Fernando
Adriano May 6, 2006 07:04
Re: UDF for unsteady spray
Hi, i think your problem is in the definition of the pointer 'p'. in subroutine you're using *p need to be passed to macros as Tracked_Particle type, so let's try to declare: 'Tracked_Particle *p' instead of 'Particle *p
I might be wrong but, It could be a solution.
Seeu Adriano Z
Fernando May 6, 2006 13:52
Thanks Adriano. I tried it but it still does not want to compile.
Adriano May 8, 2006 12:19
I'm working in a similar code and I've similar problems... so mahh?!?!
Fernando May 9, 2006 08:47
Adriano, I have corrected the UDF and it is compiling fine. If you see this send me an e-mail and I will send you the file. lopar30@hotmail.com
Regards
Fernando
