Batch Processing and auto-save option
Like Tree2Likes
  • 2 Post By VV
Old   May 6, 2006, 21:54
Default Batch Processing and auto-save option
Vimal
I am trying to run an unsteady case with FLUENT using the batch processing option. I am having some trouble with the auto-save option when the run-script is used in the batch-mode (run-script attached below).
(1) Even though the auto-save frequency is set to 10, no case or data files are generated at the end of the simulation.
(2) I know there is a brute-force solution to this problem by writing a script
it 20 wc RT1_0020.cas wd RT1_0020.dat
it 20 wc RT1_0040.cas wd RT1_0040.dat
.... .... .... etc.
Is there a way of getting around this using loops?
Thanks
Vimal ================================================== ========== ; Read Case File rc RD234SL.cas
; Set Auto-save Options /file/autosave/case-frequency 10 /file/autosave/data-frequency 10 /file/autosave/overwrite-existing-file yes /file/autosave/root-name "RT1_"
/file/confirm-overwrite no
; Mark Region for VOF patch /adapt/mark-inout-rectangle yes no -0.5 +0.5 -0.5 +0.0
(rpsetvar 'patch/vof? #t)
; Initialize the Solution /solve/initialize/initialize-flow
; Patch Water Volume Fraction /solve/patch water () (0) mp 1
; Set time-step /solve/set/time-step 0.002
; Iterate it 400
; Exit Fluent exit yes ================================================== ==========
Old   May 7, 2006, 15:54
Default Re: Batch Processing and auto-save option
Vimal
I was able to find a solution... Thanks
Old   May 17, 2006, 13:42
N Pattakos
would you pls tell me what did you do? I have the same problem.
Old   May 17, 2006, 14:02
VV
I have included the batch script that I used for an unsteady run. For a steady run, the batch-script given in the FLUENT user manual is sufficient. Hope this helps.
Regards
VV
; FLUENT RUN SCRIPT ; READ CASE FILE /file/read-case <case-name>
; AUTO-SAVE/BATCH OPTIONS file/autosave/case-frequency 25 file/autosave/data-frequency 25 file/autosave/overwrite-existing-file no
; STRING SPECIFYING FILE NAME : <string> ; AUTO-SAVE FILE : <string><iterationg count>.cas file/autosave/root-name "<string>"
; INITIALIZE FLOW /solve/initialize/initialize-flow
; SET TIME-STEP /solve/set/time-step 0.002
; ITERATE (TAKES CARE OF AUTO-SAVING) /solve/dual-time-iterate 4000
; EXIT FLUENT exit yes
Old   May 17, 2006, 14:07
VV
Regards
VV
; FLUENT RUN SCRIPT
; READ CASE FILE
; STRING SPECIFYING FILE NAME : "string"
; AUTO-SAVE FILE : "string""iteration count".cas
; INITIALIZE FLOW
; SET TIME-STEP
; EXIT FLUENT
exit yes
Amili and Jetteke like this.
