journal file: how to change window for hardcopy |
May 11, 2006, 03:18 |
Hi!
Can anyone tell me, if there is a command for the TUI or a journal file, that changes the window, that is used in the hardcopy-option? Can a new window be opened or an old be closed? e.g. I am having two windows (one for displaying residuals, one for the results) and I want Fluent to run multiple cases. After iterating each case, Fluent should hardcopy both windows. Ralf |
May 11, 2006, 04:47 |
Re: journal file: how to change window for hardcop
display set-window
May 11, 2006, 05:18 |
as far as I understand, in this menue are just options for setting the scale, axis, text that is displayed and so on...
What I want, is to switch between 2 or more windows! |
May 11, 2006, 05:44 |
the comand to make window 1 to your active window :
display set-window 1 to switch back to 0 it is : display set-window 0 there must be a hyphen between set and window |
Display Modes | |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 17:46 |
Problem with Boundary Conditions using a journal file | T.S. | FLUENT | 3 | July 27, 2009 09:31 |
[OpenFOAM] ParaView 33 canbt open OpenFoam file | hariya03 | ParaView | 7 | September 25, 2008 18:33 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 21:51 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 23:00 |
