-   -   near wall mesh guidelines - y+ to large? (http://www.cfd-online.com/Forums/fluent/40931-near-wall-mesh-guidelines-y-large.html)
Ralf Schmidt May 11, 2006 08:37
Hi!
I have a question for the near wall-mesh guidelines from Fluent.
I am modelling heat transfer from a long cylinder in axial flow of Air at Re = 20000.
I am trying to find the best turbulence model to correctly simulate heat transfer. Now, Fluent manual tells me, that for k-e model with std. and non-equilibrium wall functions as well as for the k-w model, the y+ value should be about 30.
In my case, that is resulting in a size of the first cell of about 3 mm (7,5 % of the diameter of the cylinder). And I thing, thats a very big cell.
Also, the resulting Nu and HTC values are not matching experimental data...
Any help is highly appreciated Ralf
mAx May 12, 2006 02:21
Re: near wall mesh guidelines - y+ to large?
Hi, I hae also the same problem. I am working with valves with tiny openings. I never achieved getting first cell with y+ about 30. I am always with y+ about 10. So I would refine your walls (if you hardware enable it :) ) and then switch on Enhanced Wall Treatment.
