May 11, 2006, 15:22 |
help with gambit
I installed FLUENT/Gambit on my PC but I'm not able to run it since I don't have an X-server. is there any alternate method to run FLUENT/Gambit other than Hummingbird Exceed? Thanks in advance, Regards.
May 12, 2006, 10:55 |
Re: help with gambit
X-windows is not part of the Windows OS which is why Gambit requires Exceed for windows. Fluent should be ok though. One alternative if you haven't got access to Exceed is to install a Linux OS alongside your windows OS - I run SUSE Linux (free download) alongside XP and it works very well. Steve |
May 12, 2006, 13:49 |
thanks a lot for ur help...will try n see if it works for me. thanks again, Regards.
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
3-D Mesh Check in Gambit..... | SHR | FLUENT | 4 | March 25, 2003 03:10 |
