-   -   UDF source folder dependence??? (http://www.cfd-online.com/Forums/fluent/40940-udf-source-folder-dependence.html)
Sasha May 12, 2006 00:38
Hi. I'm trying to read the UDF into Fluent. When reading it interpreted from the Fluent.inc folder - everything is working fine. On the other hand, I can't do it when the case and the .c files are in some other than Fluent.inc folder. Please help me with this. Thanks a lot.
AdN May 15, 2006 10:51
Re: UDF source folder dependence???
You have to put a file named UDF (or everything else) in the root of your hard disk. After your can save your case file everywhere on your HD. Normally it will work if you want to interpret your udf function
Hope it wil work
Sasha May 16, 2006 04:10
Thankx, I'll try this later today. Sasha
AdN May 16, 2006 04:33
I make az little mistake, You have to create a folder (and not a file) named "UDF" on the root of HD (ex: c:/UDF), and after you save your .c function in it. and your case file anywhere...
