HELP!! Somethings about Convergence criteria!!
Old   May 14, 2006, 11:24
Default HELP!! Somethings about Convergence criteria!!
maoasis
I am runing a case about the wind passing throw some buildings. The solution does not converge. I use RKE to run my case and set the convergence criteria of the residual be 10^-3.
Due to the limit of the storage of my computer, the length of downstream is about 4 time of city size so that I can save it and export as .msh file. I have setted the exit plan be the pressure outlet boundary. In the boundary (the exit), I find that there are velocity gradient alone the boundary plan. Are the length of downstream so short that my case cannot converge?
I have found from Fluent's manaul that the boundary should set a place where there are no gradient. Actually, I am not understand the meanings of this. So what does that means?
Finally, Do there any other method or criteria so that we can decide the solution is converge even if the residual do not converge?
Thanks very much!!
Old   May 14, 2006, 11:31
Default Re: HELP!! Somethings about Convergence criteria!!
Pete
Try using the pressure outlet B/C.
Old   May 14, 2006, 11:34
Pete
Oops. You are using the PO B/C. Don't worry about velocity gradients existing at the outlet. THE PO B/C takes care of that. Only if your velocity profile is NOT fully developed should you bother about the exit B/C, and that too only if you are using the OUTFLOW B/C as it is based on a fully developed flow assumption.
Old   May 14, 2006, 13:55
justin
Hi,Maoasis It may be due to the bounary condition. Most cases about wind environment use velocity (inlet) and outflow (outlet). The downstream length is about 10~12 times of the characteristic builidng height.The details can be found from website: COST ACTION C14: Urban Wind Engineering and Buildings Aerodynamics.
Good luck Justin
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
What value shall I set for the Convergence criteria? steventay CFX 7 May 14, 2010 12:44
star-ccm+ convergence criteria star Siemens 2 January 14, 2009 04:57
Convergence Criteria edwin FLUENT 1 February 14, 2008 19:24
