-   -   CPUS: which CPU is better? (http://www.cfd-online.com/Forums/fluent/40965-cpus-cpu-better.html)
Leiva May 14, 2006 12:40
I'm willing to know which CPU is better for fluent 6.2.
Between an Athlon 64 3500+ single core and a 4200+ dual core, both running at 2,2 ghz, is there going to be a great difference between them?
How about memory, is there a great difference from 1 to 2 to 4 gb?
thanks in advance
Charles May 15, 2006 03:52
Re: CPUS: which CPU is better?
There will be a great advantage to the dual-core CPU, if you have the license to run in parallel. Size of memory depends on the type of flow you are hoping to solve, but get at least 4 GB.
Leiva May 20, 2006 08:58
is it possible to make it run in parallel under windows xp sp2? thanks in advance
Charles May 20, 2006 09:02
Definitely in XP Pro. But the crucial thing is the parallel license from Fluent.
Leiva May 20, 2006 09:03
thanks a lot charles, i'll see into it!
