y+ for k-omega = 30 ???
Old   May 15, 2006, 05:59
Default y+ for k-omega = 30 ???
Ralf Schmidt
the Fluent Manual suggests to have the y+ for k-w within the log layer 30 < y+ < 300 - a value close to the lower bound is most desirable.
I do not know, if thats a good idea. I have bad results compared to the same msh with k-e and wall functions.
The other point is, that for y+ = 30, the first cell is ab. 10% of the charactersitic lenght (diamater of a cylinder in axial flow).
Any Ideas?
Ralf
Old   May 15, 2006, 11:03
Default Re: y+ for k-omega = 30 ???
fanzhong Meng
hi In Fluent user's manual,it is y* should be in the region between 30 to 300. not y+! If you want to use k-w model with enhanced wall treatment, you should alway keep your y+ close to 1. In this way, you can probably solve the boundary layer better!
fanzhong Meng
Old   May 16, 2006, 02:05
Ralf Schmidt
Hi!
Thanks for your reply. But: the Fluent Manual (FLUENT 6.2 Documentation) is very clear at this point:
node466, section 11.10.4
"Near-Wall Mesh Guidelines for the k- omega Models
...if [Transitional Flows] option is not active, then the mesh guidelines should be the same as for the wall functions"
and further on:
node463, section 11.10.1
"Near-Wall Mesh Guidelines for Wall Functions
For standard or non-equilibrium wall functions, each wall-adjacent cell's centroid should be located within the log-law layer, 30 < y+ < 300. A y+ value close to the lower bound y+ = 30 is most desirable."
Now, the question might be, if it is importand to have the "Transitional Flows option" not active for a cylinder in axial flow at Re = 20000 (based on cylinder Diameter)?
Any Idea???
Ralf
Old   May 20, 2006, 17:28
Donald
Fluent's k-omega model is not good, look at the formula from standford university. Use rsm instead.
overshooting of Omega in SST komega using simpleFoam cm_jubayer OpenFOAM 2 June 7, 2020 12:52
Boundary Conditions for k omega SST dancfd OpenFOAM Pre-Processing 0 June 9, 2011 23:25
Omega at the wall sla FLUENT 0 January 10, 2011 04:16
Use of k omega turbulence model john_w OpenFOAM Running, Solving & CFD 2 September 22, 2009 05:15
Wall function implementation K Omega SSt cbarry OpenFOAM 3 August 18, 2009 10:09
