Help with surface texture
Old   May 15, 2006, 15:43
Default Help with surface texture
Kiran
Hi, I am modeling a problem in which a fluid is flowing over a sphere whose surface texture on one side is different from the other side (Surface texture on one half is smoother than the other half). Does anybody know how to model this? Any help is appreciated. Thanks in advance, Regards.
Old   May 16, 2006, 04:33
Default Re: Help with surface texture
Steve Silvester
Model the sphere in two halfs, that way you can specifiy different wall roughness heights for each half, or better, use a udf or boundary profile to specify a non constant roughness height over your sphere. This is assuming that you're modelling a fully rough or at least transitional flow regime.
Steve
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
