UDF for varying inlet velocity with z-distance
Old   May 18, 2006, 10:22
Default UDF for varying inlet velocity with z-distance
Peter Wilkins
I'm trying to write a UDF which will enable me to specify the inlet velocities at a boundary in terms of the z position of the point on the boundary. Can someone tell me what is wrong with my code (this is to specify x-velocity):
#include "udf.h"
DEFINE_PROFILE(unsteady_inlet_x_velocity, thread, position) { real z, x[ND_ND]; face_t f;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
z=x[1];
F_PROFILE(f, thread, position) = -1*0.129112*(z*10);
end_f_loop(f, thread) }
I've used similar UDFs in 2D problems but I'm not sure how to make it work in 3D. I'd appreciate it if someone can help!
Thanks very much,
Peter
Old   May 18, 2006, 11:10
Default Re: UDF for varying inlet velocity with z-distance
Siddharth Khowala
hi I think if u need the z coordinate then it should be possibly x[2].The rest seems ok .Hope it helps
regards
udf parabolic velocity inlet with unsteady case Faruk Beyca FLUENT 4 June 24, 2022 10:45
UDF paraboloid velocity inlet rosco FLUENT 10 June 2, 2017 08:01
UDF for Inlet velocity Mijin Kim FLUENT 0 September 28, 2009 04:50
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 12:32
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 09:44
