HELP needed. Species transport with heat release!!
Old   May 27, 2006, 15:41
Default HELP needed. Species transport with heat release!!
Amr
HI all,
I have been doing an unsteady 3D simulation for smoke and heat dispersion inside rooms. The source of both is like a trash basket. To introduce heat and smoke, the following options came to my mind:
1- To creat a volumetric heat source by setting a separate "fluid region" (call it fire region) in gambit and then define the heat source in Fluent. The same goes for CO2 and H2O as mass sources.
2-To creat the heat source as in (1) but avoiding the mass sources by setting the bottom of the (fire region above) as a mass flow inlet with a defined mass concentrations of CO2 and H2O.
Having said that, I wonder what happens when fluent sees my inputs in option (2). The fire region is a thin volume separated from the room volume by an "Interior" boundary face. Now, the mass flow inlet is not defined at this interior boundary face but rather defined at the bottom of the "fire region" thin volume. Is this a problem??? Could anybody guide me what option to use above???
Await your responses.
Cheers, Amr
Modelling Biomass Combustion via Species Transport Racheal FLUENT 39 January 8, 2022 07:42
Help needed in using wall BC for heat transfer analysis of heat exchanger tubes hassaan FLUENT 2 June 25, 2013 07:05
Questions for a species transport problems (snapshots attached) aleisia FLUENT 2 October 9, 2011 04:40
species transport in water lyn FLUENT 1 December 12, 2007 18:15
buoyancy and species transport riccardo FLUENT 1 September 15, 2006 07:14
