-   -   grid adaption mode NOT selectable via VNC (http://www.cfd-online.com/Forums/fluent/41081-grid-adaption-mode-not-selectable-via-vnc.html)
Ralf Schmidt May 23, 2006 06:22
Hi!
I have a strange problem: When I access the Workstation (where Fluent is running on) via VNC, I can NOT modify the grid adaption mode (adapt-> controls... it is fixed on hanging nodes!!!).
When I (or someone else) opens the same cas and dat file directly on the workstation, the grid adaption mode can be modified, even if someone else opens it via VNC.
So I thing my VNC is the problem... what VNC settings could effect the selectable options in Fluent???. Has someone experienced something like this???
Any Idea?
Ralf
p.s.: I know, conformal grid adaption is only available for 2D or axisymmetric geometries. I have both, and the mesh can be adapted with the conformal nodes option, when someone else opens it or I open it directly NOT via VNC...
Peter May 23, 2006 10:23
Re: grid adaption mode NOT selectable via VNC
Try to start Fluent with the -driver x11 switch. For example:
fluent 3ddp -driver x11
VNC is a very convenient tool. However it does not support fancy X extensions including OpenGL. The '-driver x11' switch forces fluent to use the default X11 settings which should not cause any problems.
Ralf Schmidt May 24, 2006 02:35
thats it!
wow,
thats it!!! It works! I never thought, that it will be so easy!
Thanks a lot man!
Ralf
