-   -   transparent isosurface (http://www.cfd-online.com/Forums/fluent/41084-transparent-isosurface.html)
mateus May 23, 2006 08:30
Hi!
Is it possible to make an isosurface transparent in fluent? Something simmilar to what you can do with any wall (Display-scene-display-transparency)...
I donīt know why it doesnt work with other isosurveces (for example with volume fraction).
Any help is greatelly appriciated, by MATEUS
Mark May 23, 2006 08:42
Re: transparent isosurface
Yes, you do it exactly as you would a wall.
mateus May 24, 2006 01:02
I tried but it doesn't work...any ideas?
Thanks MATEUS
mAx May 24, 2006 01:58
I assume it doesn't work on your active window. You should apply the transparency, and re-display what you want. should be then ok I have also the same problem with surface transparency
