Home > Forums > FLUENT
how to simulate supersonic flow
Old   May 24, 2006, 05:38
Default how to simulate supersonic flow
Josh
hi all, i'm a new user of Fluent. now i try to simulate 2-D supersonic wind tunnel (theoritically the velocity will start from subsonic, then accelerate to supersonic, then become subsonic again with occurence of normal/oblique shock) using inviscid model. i'm using pressure inlet, pressure outlet, and wall boundry conditions. the problem is that the solution is always divegence if i use coupled implicit. if i use coupled explicit, the residuals will osilate and never become converge. so what must i do now?
Old   May 24, 2006, 05:51
Default Re: how to simulate supersonic flow
Cyril
Try with pressure far field for your inlet and oulet boundary conditions.
Old   May 26, 2006, 04:38
Josh
hi cyril, i've used the pressure far field boundary condition, but the solutions never become converge. so what should i do?
Old   May 26, 2006, 10:42
sadoun
Air flow through the engine intake valve(GDI) What is the best B.C to the model
Thread Tools
Trackbacks are On
Modelling Supersonic TwoPhase Flow with Phase Change wes OpenFOAM Running, Solving & CFD 8 April 26, 2016 07:21
Supersonic Flow through Nozzle varun OpenFOAM Running, Solving & CFD 6 October 9, 2012 03:55
supersonic flow problem yekaniyasari OpenFOAM Running, Solving & CFD 0 April 14, 2008 07:02
Wedge in supersonic flow didomenico OpenFOAM Running, Solving & CFD 0 September 22, 2005 02:56
Supersonic flow calculation Valery Ponyavin FLUENT 3 March 28, 2004 22:28
