May 24, 2006, 05:38 |
how to simulate supersonic flow
hi all, i'm a new user of Fluent. now i try to simulate 2-D supersonic wind tunnel (theoritically the velocity will start from subsonic, then accelerate to supersonic, then become subsonic again with occurence of normal/oblique shock) using inviscid model. i'm using pressure inlet, pressure outlet, and wall boundry conditions. the problem is that the solution is always divegence if i use coupled implicit. if i use coupled explicit, the residuals will osilate and never become converge. so what must i do now?
May 24, 2006, 05:51 |
Re: how to simulate supersonic flow
Try with pressure far field for your inlet and oulet boundary conditions.
May 26, 2006, 04:38 |
hi cyril, i've used the pressure far field boundary condition, but the solutions never become converge. so what should i do?
May 26, 2006, 10:42 |
Air flow through the engine intake valve(GDI) What is the best B.C to the model
Modelling Supersonic TwoPhase Flow with Phase Change | wes | OpenFOAM Running, Solving & CFD | 9 | July 27, 2021 11:05 |
Supersonic Flow through Nozzle | varun | OpenFOAM Running, Solving & CFD | 6 | October 9, 2012 03:55 |
supersonic flow problem | yekaniyasari | OpenFOAM Running, Solving & CFD | 0 | April 14, 2008 07:02 |
Wedge in supersonic flow | didomenico | OpenFOAM Running, Solving & CFD | 0 | September 22, 2005 02:56 |
Supersonic flow calculation | Valery Ponyavin | FLUENT | 3 | March 28, 2004 22:28 |
