Manipulate UDF
Old   May 23, 2006, 08:23
Default Manipulate UDF
AdN
Hello!
I want to know if it's possible to launch a DEFINE_PROPERTY only at the first iteration of a time step? TTTTThank you
Old   May 23, 2006, 15:10
Default Re: Manipulate UDF
Adriano
try to define a macro that execute on demand your DEFINe_PROPERTY udf!. hook this macro in solve/execute command GUI menu. I hope it's helpful regards Adriano
Old   May 24, 2006, 04:53
AdN
Hello Adriano,
Thank you for yourt help. But can you help me again please? Because i'm not familiar with the execute command. I interpret my UDF function. I put my udf viscosity in material panel, and after how can I use the execute command. I read the user guide, but i don't really understand how it's work. If you have the time to help me, I'll be greatful...
Thank you again
Old   May 25, 2006, 04:08
adriano
Macros record your moviments in GUI pannel so, after starting to record them (/execute command/macro/start) make as u're appling the condition for the first time(i.e.: click on define/udf/execute on demand --->hook your udf --->execute it). After stop your macro. and set it as a running command on execute window (each time step for example). run your simulation.
It may run.I hope. Regards A
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
