How many nodes to create a mesh??
Old   May 26, 2006, 17:23
Default How many nodes to create a mesh??
Vidya Raja
Hi, When I try to mesh my geometry, I get error messsage saying that some of the faces have less than three boundary nodes and so couldn't be meshed. I don't understand this - why does a mesh need at least 3 boundary nodes? How does that influence meshing?
I have 2 tiny edges of the order of 1E-5 and I simply am not able to delete them or do any other modification to suppress their effect. Does someone have any suggestions to deal with this problem? Also, since my geometry is complex, I have several sharp and twisted angles, angular surfaces etc.
Whatever I do, the meshing operation just fails. Any suggections????
Thanks, Vidya
Old   May 27, 2006, 14:12
Default Re: How many nodes to create a mesh??
chankhar
can you send me geometry chankhar
[ICEM] how can i delect the duplicate mesh line and nodes in interface between quad and tri? snailstb ANSYS Meshing & Geometry 10 September 26, 2013 08:19
[ICEM] Can't create prism layer on 2D extruded mesh PedroC ANSYS Meshing & Geometry 19 April 19, 2011 20:48
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
