Segmentation Violation
Old   May 26, 2006, 09:55
Default Segmentation Violation
Axel
Hello Guys, I want to obtain a coefficient diffusion value with the following UDF code:
__________________________________________________
#include "udf.h" #include "sg.h" #include "mem.h"
DEFINE_ON_DEMAND(cor_diff) {
Domain *d;
Domain *sd;
Thread *t, *tc0;
face_t f;
cell_t c;
int ID =6;
real diff1[3];
real fra_mas[3], dens=0.;
real A[ND_ND],ds,es[ND_ND],A_by_es,dr0[ND_ND],dr1[ND_ND];
d = Get_Domain(1);
sd = Get_Domain(2);
t = Lookup_Thread(sd,ID);
begin_f_loop(f,t) {
tc0 = THREAD_T0(t);
c = F_C0(f,t);
INTERIOR_FACE_GEOMETRY(f,tc0,A,ds,es,A_by_es,dr0,d r1);
diff1[0] = C_DIFF_EFF(c,tc0,0);
dens = C_R(c,tc0);
fra_mas[0] = F_YI(c,tc0,0);
C_UDMI(c,t,0) = dens*diff1[0]*fra_mas[0]*dr0[0]*2; } end_f_loop(f,t) }
but after I have compiled this function and run as "execute on demand" I obtain the error "segmentation violation"... Which error I have made? Thank you for your answers.
Axel
Old   May 26, 2006, 11:19
Default Re: Segmentation Violation
Swarup
Please check whether you are trying to access something which does not exist as yet. You may be knowing, this is a common error when you try to access a memory that does not exist!
Swarup.
Old   May 26, 2006, 12:16
Axel
I noted that when I consider the face loop (also with nothing inside it) there is this error... I am trying to use an other loop...
Segmentation violation louiza FLUENT 16 June 27, 2017 15:41
Segmentation Violation Corentin FLUENT 1 February 13, 2011 01:07
Defining Multiphase by text and by gui = different result and Segmentation Violation RPJones FLUENT 0 June 9, 2009 16:24
segmentation violation wasan FLUENT 0 December 23, 2008 11:37
SEGMENTATION VIOLATION Arif FLUENT 3 May 27, 2003 08:24
