-   -   Error when loading a shared library (http://www.cfd-online.com/Forums/fluent/41143-error-when-loading-shared-library.html)
rid May 27, 2006 17:04
Hi I got some problems loading a parallel udf. When I try to compile the udf, averything works well, but , when I load it I got this error therfore i can't open my old file case and dat
oapening library "libudf"... Primitive Error at Node 1: open_udf_library: No such file or directory
Library "libudf/lnx86/3ddp_host/libudf.so" opened
inlet_x_velocity
***************** thank you for your help
Peter May 27, 2006 19:39
Re: Error when loading a shared library
If you used a fluent parallel session such as 'fluent 3ddp -t2' to build your UDF before (when you used the old case and dat files), then you will also need to start a parallel session now, before reading your case and data files.
rid May 29, 2006 11:57
Hi, i used a fluent parallel session fluent 3ddp, i build my udf before reading my case and data files.the Udf is build with success. but when i read case and data file tje same error appears:
Opening library "libudf"... Primitive Error at Node 0: open_udf_library: No such file or directory
Library "libudf/lnx86/3ddp_host/libudf.so" opened please help me
Mac May 29, 2006 13:47
Are the two machines of the same architecture (i.e. both are 32 bit or 64 bit)?
rid May 29, 2006 14:51
i used a machine with 32 bits
