How can the water cut be Set into a pipe flow‎ |
June 1, 2006, 06:49 |
Hi Fluent users:‎ I have two phase (oil-water) flow into a pipe , water flow in the button of the pipe ‎and oil in the top. I have a problem to enter the amount of water cut in the pipe ‎which it (25%) , anyone kindly tell me how can I did that?‎ Thanks ‎ Khalid ‎
June 1, 2006, 08:21 |
Re: How can the water cut be Set into a pipe flowâ
You could use a patch
[DesignModeler] DesignModeler Pipe within pipe | shields | ANSYS Meshing & Geometry | 13 | November 25, 2018 22:14 |
gambit code fluent on water pipe | acai007 | FLUENT | 0 | August 29, 2010 21:53 |
How to set the water cut | KBS | FLUENT | 1 | June 8, 2006 05:42 |
How I set the water height by given water cut | KB Saleem | FLUENT | 0 | June 4, 2006 03:48 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
