Home > Forums > FLUENT
negative pressure at throat
Old   June 1, 2006, 03:46
Default negative pressure at throat
Ramesh
Hi friends, am modelling combustion inside an cylindrical combustion chamber which has two nozzles one at inlet & one at out let,... Using Fluent 6.1 software
I need help from u people in solving some of my problems
am getting few problems in my problem,...
1. Am getting negative pressures (both static & absolute) at the throat of both the nozzles at inlet & out-let,.... what does the negative pressures at throat indicate,... is it cavitation at throat????
2. Am not getting the mass fluxes right,.. i.e., in the report fluxes,.. the mass flow rate is not matching with my experimental inlet & outlet condition,... what could be the reason for this ???
3. Am using fuel injection for injecting fuel to the combustion chamber,... some times the fuel injected is not getting evoporated,.. what should i do so that the injected fuel gets evoporated???
Please suggest me some thing so that i can complete my Project with in time,....
Waiting for reply,
Regards,
Ramesh,...
Thread Tools
Trackbacks are On
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
seeking for help about a room with negative pressure mengyue1 FLUENT 0 November 26, 2009 07:40
High pressure in rhopSonicFoam results in negative pressure shangzung OpenFOAM 0 November 5, 2009 04:24
negative pressure in cfx flar.t CFX 1 December 19, 2006 00:20
negative pressure mAx FLUENT 0 January 25, 2006 15:31
