-   FLUENT (
-   -   two stage steam turbine (
sebastian June 1, 2006 07:25
I calculate two stage of steam turbine (high pressure stage), i have problem with mass flow - it is much lower than for 0D calculations (20%). I used both coupled and segregate solver. can you help me?
sam June 1, 2006 08:18
Re: two stage steam turbine
did u make grid indpendence study?
sebastian June 1, 2006 08:26
yes I made, and for all cases mass flow is similar I also checked different turbulence models and the problem still exist for different cases
sam June 2, 2006 15:34
can u send ur goemtry and boundary conditions file
sebastian June 5, 2006 01:46
no i cannot
Razvan June 6, 2006 15:27
Does your 0-dimensional model take into account effects like area shrinkage due to boundary layers, pressure losses at tip gaps, boundary layer separation, radial flow, etc.? 20% is not that much to me!
sebastian June 7, 2006 02:15
this 0-dimensional model seems to be ok, it takes into account all the mentioned efects, maybe the problem are the magnitude of pressure losses (for 0-D model). the factor for calculation of them is not proper. i calculate partial admission stage (i have four valves) with the second stage. maybe the problem is with the area between these two stages (it is quite big) i am not sure. if i calculate the case where 2 valves are opened the mass flow is ok, for case with 4 opened valves the mass flow differences are big. when i calculate only admission stage the mass flow rate from my calculation is equal to the one from 0-D. so i am not sure what to do yet.
